Put -> File Path? (Batch)
dersebi
I need a script (batch) which uploads files from a local windows machine (2008 R2) to a FTP-Server.
"C:\Program Files (x86)\WinSCP\winscp.com" /command ^
"open sftp://ID:PW@SERVER.COM" ^
"put ""*.data""" ^
"exit"
I also tried it with a temppath, but that also didn't worked.
set TMPPATH=C:\tmp\temppath
"put ""*.data"" ""TMPPATH""" ^
"exit"
Everytime the script can connect to the server but then it stops.
I can enter exit and then I get the error in the attached screenshots.
Do I have to enter the path where the files which I want to upload in the skript? If yes where or how can I enter the path?
Anyone can help me?
Thanks & Regards
Re: Put -> File Path? (Batch)
The ^ has to be the very last character on batch file line for it to work correctly to escape the new line. No spaces after it are allowed.
Hey Martin,
i changed the script.
Still the same problem.
The script stops and if I enter "Exit" I get the error.
How can I set the path where the files are uploaded from?
Regards
Sebi
dersebi
Hey Martin,
just forget it .
There was a mistake in my code.
The filepath has to be with 1 ", I used 2.
Thanks for help. (#close)
Regards
Sebi
Sorry, delete the Guest Post.
I forgot to log in.</s>
