A script to download, rename, and move files
EliF_Teepee
Illinois
Up until now, I have been been using WS_FTP but would like to switch to WinSCP.
I'm trying to convert this WS_FTP script into WinSCP:
"C:\Program Files (x86)\Ipswitch\WS_FTP 12\wsftppro.exe"
-s "sftp://USERNAME:PASSWORD@ftpus.pointclickcare.com/USERNAME/logs/*.sqb"
-d "local:C:\PccDataRelay\LogDownloads\"
-rename tx_[yyyy]-[mm]-[dd]_[hh]-[tt]-[ss]_[OnlyName].[OnlyExt]
-move "/USERNAME/logs/transferred/"
I've been able to convert it partially:
cd C:\PccDataRelay\TestDownloads
"C:\Program Files (x86)\WinSCP\winscp.com" /ini=nul /log=C:\PccDataRelay\AuditLogs\incremental_download.log /command ^
    "open sftp://USERNAME:PASSWORD@ftpus.pointclickcare.com/USERNAME/logs/ -hostkey=""ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" ^
    "get /USERNAME/logs/*.sqb" ^
    "exit"
But that only downloads the files. How can I get it to rename and move the original files while also leaving them in-place on the FTP site?
Please note, I posted this question subsequently to StackOverflow as the issue is timely.
Thank you!
ajay1993
United States
Get ftp files with timestamp + filename
Hello Martin sir,
I am trying to create automation script to download files from FTP server that are autogenerated every hour. I want to get filename as YYMMDD(File name) format (eg:19062400), which I am not able to get it. right now I am getting files with a name (00.190624)
My script is
open ftp://usrname:password.urlftp.com/
binary
get -neweronly "*.csv" "c:\PBI-files\*.%TIMESTAMP#yymmdd%.csv"
Can you help me to get that format?
Thanks.
Re: Get ftp files with timestamp + filename
@ajay1993: Your question is not really clear, but I assume you want this:
get -neweronly "%TIMESTAMP#yymmdd%*.csv" "c:\PBI-files\"
(the combination of -neweronly and %TIMESTAMP% is suspicious too, but hopefully you know what you are doing).
I have tried the code that you sent me, it throws me an error of
No matching files found 190625*
My question was, I want to download multiple and only newly generated files from FTP server to the local directory with timestamp and filename according to this name format "(Timestamp)(filename)"
tried every other combination as follows:
winscp> get "%TIMESTAMP#yymmdd%*.csv" "c:\PBI-files\"
No file matching '190625*.csv' found.
mget -neweronly "%TIMESTAMP#yymmdd%*.csv" "c:\PBI-files\"
FTP directory has files names as 00.csv, 01.csv, 02.csv and so on.
Earlier you wrote that "I want to get filename as YYMMDD(File name) format (eg:19062400),". Now you claim something entirely different.
