Text display issues with Wine.
randomguy
I'm almost installing a VM only to use Winscp with linux!
This is my system settings:
Ubuntu 16.04 x64, kernel 4.13.0-26-generic.
wine-2.21 (Staging)
Only libnetapi.so is missing. I'm using a windows xp profile with GTK3 theming.
Both portable and installed versions have this issue.
Please help me :( I really need winscp.
randomguy
wine output running the .exe files
fixme:winediag:start_process Wine Staging 2.21 is a testing version containing experimental patches.
fixme:winediag:start_process Please mention your exact version when filing bug reports on winehq.org.
fixme:module:load_dll Loader redirect from L"uxtheme.dll" to L"uxtheme-gtk.dll"
fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
fixme:module:load_dll Loader redirect from L"UXTHEME.DLL" to L"uxtheme-gtk.dll"
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
fixme:wtsapi:WTSRegisterSessionNotification Stub 0x1008a 0x00000000
fixme:shell:CustomDestinationList_BeginList 0x16bf28 (0x33fc54 {92ca9dcd-5622-4bba-a805-5e9f541bd8c9} 0x33fc60): stub
fixme:msg:ChangeWindowMessageFilterEx 0x1008a c058 1 (nil)
fixme:uxthemegtk:OpenThemeDataEx No matching theme for L"Treeview".
err:listview:LISTVIEW_WindowProc unknown msg 109d wp=00000000 lp=00000000
(WinSCP.exe:31435): Gtk-WARNING **: /build/gtk+3.0-8XQQjd/gtk+3.0-3.18.9/./gtk/gtkwidget.c:13181: widget class 'GtkWindow' has no property named 'resize-grip-width'
fixme:uxthemegtk:DrawThemeText No color.
fixme:uxthemegtk:OpenThemeDataEx No matching theme for L"Spin".
fixme:win:WINNLSEnableIME hwnd 0x101c0 enable -1: stub!
fixme:win:WINNLSEnableIME hwnd 0x101c2 enable -1: stub!
Re: Text display issues with Wine.
So you get this problem with all checkboxes in a groupbox?
Anyway, you should report this to Wine project. We cannot do anything about it.
