Question about locationprofiles usage/possibilities
I like the locationprofiles in WinSCP but I'm wondering if there te possibility to start a WinSCP-session with different locationprofiles?
What do I mean with that:
If I need to connect to a remote server to check something about lets say 'usage1' i would like to have the directories '/io/usage1' and '/log/usage1' in my locationprofiles list because those are the directories that are used for that functionality.
If I want to connect to the same remote server and i want to check 'usage2' then I would like to have other directories in that locationprofiles because for that usage2 i need files from other directories then for usage1.
Is that in some way possible in WinSCP? maybe by starting with command line or ??
Regards
Didier
Regards
Didier
