Unable to use new SessionOptions statement in SSIS Script Task
joerobbi
I'm attempting to use the WinSCP assembly for the first time in SSIS, and I can't seem to get it to work (code below). The Script task fails each time with that useless "Exception has been thrown by the target of an invocation" error. Starting at the bottom and incrementally commenting out code, it doesn't start running until I comment out the SessionOptions soOpt = new SessionOptions lines. WinSCP is installed, and I've added the assembly as a Reference on the task, but no joy. Any help would be very much appreciated!
Actual Code (servers/filenames redacted):
using System;
using System.Data;
using Microsoft.SqlServer.Dts.Runtime;
using System.Windows.Forms;
using WinSCP;
public void Main()
        Protocol = Protocol.Sftp
        ,SshHostKeyFingerprint = "ssh-rsa 2048 00:00..."
        ,HostName = "server.company.com"
        ,UserName = "UserName"
        ,SshPrivateKeyPath = @"X:\Directory\Key_Private.ppk"
    using (Session seNew = new Session())
        seNew.ExecutablePath = @"E:\Program Files (x86)\WinSCP\winscp.exe";
        seNew.Open(soOpt);
        TransferOptions xfrOptions = new TransferOptions();
        xfrOptions.TransferMode = TransferMode.Binary;
        TransferOperationResult xfrResult;
        xfrResult = seNew.GetFiles(@"/home/UserName/file.txt", @"X:\Directory\file.txt", false, xfrOptions);
        xfrResult.Check();
Re: Unable to use new SessionOptions statement in SSIS Script Task
The exception has an inner exception for sure. What is it?
joerobbi
That's part of what's killing me; I can't seem to trap an exception from the Script task. Try/Catch and full logging for that task give the error log below.
I admit I'm no expert, so if there's another way to catch that inner exception, I'm all ears. :-)
------------Error Log---------------
OnPreValidate,ServerName,Domain\User,Script_Download,{199F7AF1-A521-4E98-9596-0FD4B91E3FFF},{222A4A31-33C8-48FC-A176-B8663227477E},1/25/2018 8:45:23 AM,1/25/2018 8:45:23 AM,0,0x,
OnPostValidate,ServerName,Domain\User,Script_Download,{199F7AF1-A521-4E98-9596-0FD4B91E3FFF},{222A4A31-33C8-48FC-A176-B8663227477E},1/25/2018 8:45:23 AM,1/25/2018 8:45:23 AM,0,0x,
OnError,ServerName,Domain\User,Script_Download,{199F7AF1-A521-4E98-9596-0FD4B91E3FFF},{222A4A31-33C8-48FC-A176-B8663227477E},1/25/2018 8:45:24 AM,1/25/2018 8:45:24 AM,1,0x,Exception has been thrown by the target of an invocation.
OnTaskFailed,ServerName,Domain\User,Script_Download,{199F7AF1-A521-4E98-9596-0FD4B91E3FFF},{222A4A31-33C8-48FC-A176-B8663227477E},1/25/2018 8:45:24 AM,1/25/2018 8:45:24 AM,0,0x,
OnPostExecute,ServerName,Domain\User,Script_Download,{199F7AF1-A521-4E98-9596-0FD4B91E3FFF},{222A4A31-33C8-48FC-A176-B8663227477E},1/25/2018 8:45:24 AM,1/25/2018 8:45:24 AM,0,0x,
Carlos Letona
I was getting the same exception error, but I just added a static script. By loading the path of the WinSCP.dll, and it worked.
static ScriptMain()
    AppDomain.CurrentDomain.AssemblyResolve += new ResolveEventHandler(CurrentDomain_AssemblyResolve);
static Assembly CurrentDomain_AssemblyResolve(object sender, ResolveEventArgs args)
    if (args.Name.Contains("WinSCPnet"))
        string path = @"C:\Program Files (x86)\WinSCP";
        return Assembly.LoadFile(Path.Combine(path, "WinSCPnet.dll"));
    return null;
This all is already documented:
