Powershell: Exception on New-Object WinSCP.Session
tmontana3x
i hope you may help. I have Powershell 6 and when i try to New-Object WinSCP.Session i get the following error:
new-object : Exception calling ".ctor" with "0" argument(s): "Could not load type 'System.Diagnostics.PerformanceCounter' from assembly 'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'."
At line:1 char:1
+ new-object winscp.session
+ CategoryInfo : InvalidOperation: (:) [New-Object], MethodInvocationEx
ception
+ FullyQualifiedErrorId : ConstructorInvokedThrowException,Microsoft.PowerShell.
Commands.NewObjectCommand
I hope you can help me.
Thank you
Re: Powershell: Exception on New-Object WinSCP.Session
I'm not yet familiar with PowerShell Core 6, but note that WinSCP .NET assembly needs a full .NET Framework, not just .NET Core. So that can be the problem.
tmontana3x
Hello, thanks for the info, so i can just install .net framework (version?) and everything fine? Or does PS6 only accept .net core?
Best!
Best!
Hello again, Dot Net Framework 4.7.1 is already installed... any other ideas?
Re: Solved
tmontana3x wrote:
as i found out ps 5.1. is also available on the system - with that its working
So before, did you try to use WinSCP from pwsh.exe?
