File Excluded?
I have WinSCP on two computers from which I wish to upload some files to an IIS server I manage. I set up the SFTP on the server, opened WinSCP interactively on the first local machine, and successfully uploaded a file to test my implementation. I then went to my second computer, opened WinSCP using the same username/password/settings, logged in to the remote successfully, see the remote directory.... but when I try to uplaod a file I get a message that the file was excluded (I am only trying to upload one file). The log below shows that WinSCP is actively excluding and I can't figure out why.
Thanks for any help,
Greg
. 2018-01-25 09:05:55.079 Session upkeep
. 2018-01-25 09:05:55.589 Session upkeep
. 2018-01-25 09:05:56.094 Session upkeep
. 2018-01-25 09:05:56.249 Copying 1 files/directories to remote directory "/" - total size: 0
. 2018-01-25 09:05:56.249 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2018-01-25 09:05:56.249 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: Yes; InclM: *.csv; ResumeL: 0
. 2018-01-25 09:05:56.249 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2018-01-25 09:05:56.254 File "S:\testfile.txt" excluded from transfer
* 2018-01-25 09:05:56.254 (EScpSkipFile)
. 2018-01-25 09:05:56.254 Copying finished: Transferred: 0, Elapsed: 0:00:00, CPS: 0/s
. 2018-01-25 09:05:56.254 Retrieving directory listing...
> 2018-01-25 09:05:56.254 TYPE A
< 2018-01-25 09:05:56.329 200 Type set to A.
> 2018-01-25 09:05:56.329 PASV
< 2018-01-25 09:05:56.404 227 Entering Passive Mode (184,161,21,7,195,28).
> 2018-01-25 09:05:56.404 LIST -a
. 2018-01-25 09:05:56.404 Connecting to 180.166.21.7:49948 ...
. 2018-01-25 09:05:56.479 Data connection opened
. 2018-01-25 09:05:56.479 Trying reuse main TLS session ID
< 2018-01-25 09:05:56.479 150 Opening ASCII mode data connection.
. 2018-01-25 09:05:56.479 TLS layer changed state from none to connected
. 2018-01-25 09:05:56.674 Session ID reused
. 2018-01-25 09:05:56.674 TLS connect: SSLv3 read server hello A
. 2018-01-25 09:05:56.674 TLS connect: SSLv3 read finished A
. 2018-01-25 09:05:56.674 TLS connect: SSLv3 write change cipher spec A
. 2018-01-25 09:05:56.674 TLS connect: SSLv3 write finished A
. 2018-01-25 09:05:56.674 TLS connect: SSLv3 flush data
. 2018-01-25 09:05:56.674 Using TLSv1, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA, 2048 bit RSA, ECDHE-RSA-AES256-SHA SSLv3 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA1
. 2018-01-25 09:05:56.674 TLS connection established
< 2018-01-25 09:05:57.249 226 Transfer complete.
. 2018-01-25 09:05:57.249 TLS layer changed state from connected to closed
. 2018-01-25 09:05:57.249 Data connection closed
Greg
