Setting for saving session names to disk ("forward slash" ("/"))
hrvoj3e
When using "Append session name to temporary path" some editors have problems with char "forward slash" ("/") which is used as delimiter for folder and session.
Preferences > Storage
[x] Use temporary directory of system : D:\code\winscp\
[x] Append session name to temporary path
[x] Append remote path to temporary path
[x] Keep temporary copies of remote files in deterministic paths
[ ] Cleanup obsolete temporary directories on startup
If I have sessions
MyServer
  |- user1
  |- user2
If I open a file for editing in a custom editor with setting as above mentioned I get
D:\code\winscp\MyServer%2Fuser1\var\www\some\path\some.file.css
Some editors have problems with "%2F" and are trying to open wrong path:
D:\code\winscp\MyServer\user1\var\www\some\path\some.file.css
It would be useful to me to have a setting which defines this delimiter "forward slash" ("/").
For example, logging uses delimiter "-" for session names D:\code\winscp_log\MyServer-user1.log
Re: Setting for saving session names to disk ("forward slash" ("/"))
What "some editors"?
This request has been added to the tracker:
https://winscp.net/tracker/1608
hrvoj3e
The version you sent me works great!
Thank you Martin :)
