Downloading files using GetFiles
ejw
In a C# application I want to download one hidden file in a directory on a remote server.
If I try to download this file using ftp protocol and GetFiles(), an exception is generated: Exception thrown: 'WinSCP.SessionRemoteException' in WinSCPnet.dll. If I remove the hidden attribute on the remote server, everything works fine. How can I download hidden files on the remote server using C#?
Thanks in advance.
Re: Downloading files using GetFiles
Please attach a full session log file for both scenarios (using the latest version of WinSCP).
ejw
Request logfile
Sir,
In the attachement I've included a logfile. Please not that
the file _mydocument.txt in the logfile is a file that has the hidden flag
(hidden file)
  • winscplog.txt (11.25 KB, Private file)
Re: Request logfile
As you can see in the log, while the server includes the hidden file in a directory listing, it rejects its download. Looks like a bug to me.
I do not think that you can do anything about it. You should get the same problem with any other FTP client.
ejw
Re: Request logfile
OK, I thought it had something to do with the listing functionality in WinSCP.
maybe add option to skip downloading hidden files, or report hidden files being skipped?
Re: Request logfile
But there's no way WinSCP can tell that the file is hidden. To WinSCP the file looks like any other.
