Group, Owner, Permissions
someone
I've been trying to use WinSCP and OpenSSH using the instructions here: https://winscp.net/eng/docs/guide_windows_openssh_server
However, I was stuck in this part:
Ensure that your account home directory, your .ssh directory and file authorized_keys are not group-writable or world-writable. Recommended permissions for .ssh directory are 700. Recommended permissions for authorized_keys files are 600. Read more about changing permissions.
When I create a .ssh folder, I assign 0700 in the Octal text box. It was created but when I right click->Properties, Octal was still 0777 and Group: - [0] and Owner: - [0]. I believe this is why when I try to connect via public key authentication, I am getting 'server refused our key' error. Also, Checksum is disabled. Am I missing something from the instructions? I am using SFTP.
Thanks!
LOG:
. 2018-02-18 12:40:42.809 Using SFTP protocol.
. 2018-02-18 12:40:42.809 Doing startup conversation with host.
> 2018-02-18 12:40:42.824 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2018-02-18 12:40:42.824 Type: SSH_FXP_VERSION, Size: 150, Number: -1
. 2018-02-18 12:40:42.824 SFTP version 3 negotiated.
. 2018-02-18 12:40:42.824 Unknown server extension posix-rename@openssh.com="1"
. 2018-02-18 12:40:42.824 Supports statvfs@openssh.com extension version "2"
. 2018-02-18 12:40:42.824 Unknown server extension fstatvfs@openssh.com="2"
. 2018-02-18 12:40:42.824 Supports hardlink@openssh.com extension version "1"
. 2018-02-18 12:40:42.824 Unknown server extension fsync@openssh.com="1"
. 2018-02-18 12:40:42.824 We believe the server has signed timestamps bug
. 2018-02-18 12:40:42.824 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2018-02-18 12:40:42.824 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2018-02-18 12:40:42.824 Changing directory to "/C:/Users/sample/Documents/SFTP Server".
. 2018-02-18 12:40:42.824 Getting real path for '/C:/Users/sample/Documents/SFTP Server'
> 2018-02-18 12:40:42.824 Type: SSH_FXP_REALPATH, Size: 49, Number: 16
< 2018-02-18 12:40:42.824 Type: SSH_FXP_NAME, Size: 101, Number: 16
. 2018-02-18 12:40:42.824 Real path is '/C:/Users/sample/Documents/SFTP Server'
. 2018-02-18 12:40:42.824 Trying to open directory "/C:/Users/sample/Documents/SFTP Server".
> 2018-02-18 12:40:42.824 Type: SSH_FXP_LSTAT, Size: 49, Number: 263
< 2018-02-18 12:40:42.824 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2018-02-18 12:40:42.824 Getting current directory name.
. 2018-02-18 12:40:42.878 Listing directory "/C:/Users/sample/Documents/SFTP Server".
> 2018-02-18 12:40:42.878 Type: SSH_FXP_OPENDIR, Size: 49, Number: 523
< 2018-02-18 12:40:42.878 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2018-02-18 12:40:42.878 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2018-02-18 12:40:42.878 Type: SSH_FXP_NAME, Size: 169, Number: 780
> 2018-02-18 12:40:42.878 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2018-02-18 12:40:42.878 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2018-02-18 12:40:42.878 Status code: 1
> 2018-02-18 12:40:42.878 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
. 2018-02-18 12:40:42.878 sample@localhost.log;-;7621;2018-02-18T04:40:40.000Z;3;"-" [0];"-" [0];rw-******;1
. 2018-02-18 12:40:42.878 ..;D;0;1899-12-30T08:00:00.000Z;0;"" [0];"" [0];---------;0
. 2018-02-18 12:40:42.909 Startup conversation with host finished.
. 2018-02-18 12:44:54.868 Creating directory ".ssh".
. 2018-02-18 12:44:54.870 Canonifying: ".ssh"
. 2018-02-18 12:44:54.870 Getting real path for '/C:/Users/sample/Documents/SFTP Server/.ssh'
> 2018-02-18 12:44:54.870 Type: SSH_FXP_REALPATH, Size: 54, Number: 1808
< 2018-02-18 12:44:54.873 Type: SSH_FXP_STATUS, Size: 24, Number: 1284
. 2018-02-18 12:44:54.873 Discarding reserved response
< 2018-02-18 12:44:54.878 Type: SSH_FXP_NAME, Size: 111, Number: 1808
. 2018-02-18 12:44:54.878 Real path is '/C:/Users/sample/Documents/SFTP Server/.ssh'
. 2018-02-18 12:44:54.878 Canonified: "/C:/Users/sample/Documents/SFTP Server/.ssh"
> 2018-02-18 12:44:54.878 Type: SSH_FXP_MKDIR, Size: 58, Number: 1550
< 2018-02-18 12:44:54.908 Type: SSH_FXP_STATUS, Size: 24, Number: 1550
< 2018-02-18 12:44:54.908 Status code: 0
> 2018-02-18 12:44:54.908 Type: SSH_FXP_LSTAT, Size: 54, Number: 2055
< 2018-02-18 12:44:54.915 Type: SSH_FXP_ATTRS, Size: 37, Number: 2055
> 2018-02-18 12:44:54.915 Type: SSH_FXP_SETSTAT, Size: 62, Number: 2313
< 2018-02-18 12:44:54.920 Type: SSH_FXP_STATUS, Size: 24, Number: 2313
< 2018-02-18 12:44:54.920 Status code: 0
. 2018-02-18 12:44:54.920 Listing directory "/C:/Users/sample/Documents/SFTP Server".
> 2018-02-18 12:44:54.920 Type: SSH_FXP_OPENDIR, Size: 49, Number: 2571
< 2018-02-18 12:44:54.923 Type: SSH_FXP_HANDLE, Size: 13, Number: 2571
> 2018-02-18 12:44:54.923 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
< 2018-02-18 12:44:54.925 Type: SSH_FXP_NAME, Size: 273, Number: 2828
> 2018-02-18 12:44:54.928 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
< 2018-02-18 12:44:54.933 Type: SSH_FXP_STATUS, Size: 28, Number: 3084
< 2018-02-18 12:44:54.933 Status code: 1
> 2018-02-18 12:44:54.933 Type: SSH_FXP_CLOSE, Size: 13, Number: 3332
. 2018-02-18 12:44:54.933 .ssh;d;0;2018-02-18T04:44:54.000Z;3;"-" [0];"-" [0];rwx******;3
. 2018-02-18 12:44:54.933 sample@localhost.log;-;9693;2018-02-18T04:40:44.000Z;3;"-" [0];"-" [0];rw-******;1
. 2018-02-18 12:44:54.933 ..;D;0;1899-12-30T08:00:00.000Z;0;"" [0];"" [0];---------;0
someone
Thank you martin. One last query. Does having - [0] as Group and Owner boxes have effect on the .ssh folder access? Why was it [0] in the first place? I have been seeing tutorials or even the one in here: https://winscp.net/eng/docs/ui_properties where Group was users[546] and Owner was martinp[1002].
Mine was - [0] and I was logged on in WinSCP as the usual User in my machine (I was the only user). Your response will be much much appreciated.
It's about how a non *nix SSH server presents advanced remote ACL via simple *nix style permissions. Some may try to at least partially present the permissions somehow. Some (what seems to be the case) simply send 0 and ignore any changes.
