Host key does not match configured key ssh-rsa
As you can see it only compares the first word of the hostkey string against the whole chain.
command wrote on powershell:
I've tried double-double-quoting:
I've tried mixing simple and double-quoting:
I've tried escaping the inner quotes:
...nothing worked.
But, if I start winscp, and run the open command inside it works.
open sftp://user:password@example.com/ -hostkey="ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e"
I'm using the wildcard style for now:
But I don't feel confortable with it...
PS C:\Windows\system32> WinSCP.com /log="C:\writable\path\to\log\WinSCP.log" /ini=nul /command "open sftp://user:password@example.com/ -hostkey=""ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e""" Error occurred during logging. It's been turned off. Can't open log file 'C:\writable\path\to\log\WinSCP.log'. System Error. Code: 2. The system cannot find the file specified Searching for host... Connecting to host... Authenticating... Host key does not match configured key "ssh-ed25519"! Host key fingerprint is ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e. Authentication failed.
'open sftp://user:password@example.com/ -hostkey="ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e"'
"open sftp://user:password@example.com/ -hostkey=`"ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e`""
...nothing worked.
PS C:\Windows\system32> WinSCP.com winscp> open sftp://user:password@example.com/ -hostkey="ssh-ed25519 256 1d:de:80:c5:4f:d6:72:1d:be:94:51:6b:53:9a:93:4e" Searching for host... Connecting to host... Authenticating... Using username "user". Authenticating with pre-entered password. Authenticated. Starting the session... Session started. Active session: [1] user@example.com winscp>
"open sftp://user:password@example.com/ -hostkey=*"
