Help with script for unzipping multiple ZIPs on remote server
Using WinSCP version 5.13 on Windows 10, I've been using a script file to upload a large number of ZIPs to my Godaddy web server.
Now I'm trying to run a second script to unzip those ZIP files in multiple folders (200+ folders; one ZIP file per folder), using the command
call unzip /foldername001/zipname001.zip "!"
call unzip /foldername002/zipname002.zip "!"
etc., where the "!" is meant to instruct unzip to put the contents of the ZIP file in the current folder
I know I can do this manually using the Godaddy File Manager, but it's a very tedious task which I will have to over and over again whenever my files get updated.
The log file reads:
<session xmlns="http://winscp.net/schema/session/1.0" name="xxxx@xxxx.com" start="2018-02-24T11:10:37.855Z">
<call>
<command value="unzip /foldername001/zipname001.zip "!"" />
<destination value="/" />
<output value="500 Unknown command" />
<result success="false">
<message>Unknown command</message>
</result>
</call>
<failure>
</failure>
</session>
Question: what do I need to change to make the call to the unzip command work? Ideally, unzip would overwrite the existing files and then the ZIP file itself would get deleted.
Any help would be much appreciated.
fp63
The log file reads:
<call>
</result>
</call>
<failure>
</failure>
</session>
fp63
