Unable to use the 'Seach Text feature.'
Martineau
'Search Text' on Remote files via SCP session to Asus Router RT-AC68U Firmware v384.4Beta1.
WinSCP v5.13 FAIL
Error: Exception calling "ParseUrl" with "1" argument(s): "Root folder can be specified for WebDAV protocol only
Parameter name: url"
Press any key to exit...
Reverting to a specific WinSCP version and the 'Search Text' function will work.
e.g.
WinSCP v5.11.3 OK
Win10 version 1709 Build 16299.248
Re: Unable to use the 'Seach Text feature.'
In WinSCP 5.13, please hold down Shift+Ctrl when clicking "OK" on "Option for extension 'Search for Text'" dialog.
The extension command gets copied to clipboard (instead of being executed). Please paste the command here (after you obfuscate the credentials).
powershell.exe -ExecutionPolicy Bypass -File "C:\Program Files (x86)\WinSCP\Extensions\SearchText.WinSCPextension.ps1" -sessionUrl "scp://uuuuuu:pppppppppppp;fingerprint=ssh-rsa-WxOSOAfeKmPU+YXOjX8bhZ3S+a6YsU/ld9w6wJxzs5s=@10.88.8.1:51893/" -path "/jffs/scripts/" -text "base64" -wildcard "*.*" -pause -sessionLogPath ""
Thanks.
https://winscp.net/tracker/1622
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
