Error parsing session log file Root element is missing. Root element is missing.
GTSwindell
United Kingdom
We have an application that uses the WinSCP .NET libraries to access sFTP sites. Occassionally during the day we will get the above exception being reported during the WinSCP.Session.Open call.
EXCEPTION:
STACK TRACE:
at WinSCP.SessionLogReader.DoRead()
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)
Are you able to assist me in working out what is causing this please. I have attached the log files generated by WinSCP
Many thanks
  • FTPSession.log (16.07 KB, Private file)
  • FTPDebug.log (39.57 KB, Private file)
Re: Error parsing session log file Root element is missing. Root element is missing.
I have sent you an email with a testing version of WinSCP to the address you have used to register on this forum.
GTSwindell
United Kingdom
Hi Martin,
Many thanks. Do you have a 5.14 version of the .NET library. I'm seeing
"The version of D:\User-Applications\TNT\FTP_Service\winscp.exe (5.14.0.0) does not match version of this assembly D:\User-Applications\TNT\FTP_Service\WinSCPnet.DLL (5.13.0.0)."
Glen
Sorry, I didn't send you an updated version of the assembly itself.
Sent now.
GTSwindell
United Kingdom
Sent now.
Thanks Martin
I have attached the log and session files generated using the new library.
Many thanks
  • FTPSession.log (15.84 KB, Private file)
  • FTPDebug.log (41.51 KB, Private file)
sushma
India
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
I saw in the tracker it has been fixed. But we could not see the latest version in nuget, the latest is 5.13.1 only, i am using it already.
Still i am getting the above exception?
any suggestion?
