Issue putting file to webdav location
gk87
Hi there,
I'm lost with the following code for putting a file on a webdav location named https://webdav.domain.com/subdirectory/ and I'm hoping someone can point me to the solution.
The $session.output output is:
winscp> option batch on
batch on
reconnecttime 120
winscp> option confirm off
confirm off
winscp> option reconnecttime 120
reconnecttime 120
winscp> open "dav://account:***@webdav.domain.com%2F:443" -timeout=15
Connecting to host...
Authenticated.
Starting the session...
Session started.
Active session: [1] account@webdav.domain.com/
winscp> pwd
/:443
The error returned for the putfiles is:
Exception calling "Check" with "0" argument(s): "Error transferring file 'C:\uploadtest.csv'. 404 Not Found"
The code:
Add-Type -Path ".\WinSCP-5.13-Automation\WinSCPnet.dll"
# Setup session options
      Protocol = [WinSCP.Protocol]::Webdav
      HostName = "webdav.domain.com/"
      PortNumber = "443"
      UserName = "account"
      Password = "P@ssw0rd"
# Connect
# Upload files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Automatic
#$transferResult =
$session.PutFiles("C:\uploadtest.csv", "subdirectory/uploadtest.csv", $False, $transferOptions)
$session.PutFiles("C:\uploadtest.csv", "/subdirectory/uploadtest.csv", $False, $transferOptions)
$session.PutFiles("C:\uploadtest.csv", "./subdirectory/uploadtest.csv", $False, $transferOptions)
$session.PutFiles("C:\uploadtest.csv", "./uploadtest.csv", $False, $transferOptions)
$session.PutFiles("C:\uploadtest.csv", "/uploadtest.csv", $False, $transferOptions)
# Throw on any error
# $transferResult.Check()
I hope someone can help me.
Re: Issue putting file to webdav location
For a start, remove the slash from HostName and set WebdavSecure instead of setting PortNumber to 443.
If that does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
gk87
Hi Martin,
Thanks for the reply. Find attached the logfiles for both the opening post config and the new config as you suggested. It appears that when using your config opening the session hangs / gets in some sort of loop. No connection can be established.
      HostName = "webdav.domain.com"
      WebdavSecure = $True
  • log_oldconfig.txt (28.22 KB, Private file)
  • log_newconfig.txt (1.36 MB, Private file)
gk87
Can you connect to that WebDAV server using any WebDAV client?
I tried WinSCP and BitKinex but I'm not able to connect. The only working option is Windows Explorer (Add a network location). I also asked the webdav URL provider to clarify on this.
