open Not Completely Logging In
Trying to get this set so Winscp will keep the local (windows) folder synchronized with the remote (Linux) machine folder.
Script:
This opens winscp program itself but stops there. What am i missing? Pageant is running and logging in normally with the program is fine.
Script:
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.exe" open sftp://root@ipremoved/ -hostkey="hostkey_removed=" -privatekey="D:\Cryp\server\Private Keys\server_key.ppk" "synchronize local D:\server backups /root/winscp_sync" "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT
