How to keep Sync both alive even after synced
PakPos
I have an issue while using 'Synchronize' with 'both' mode. Why after both local and remote synced the connection terminated (not keep alive like using 'Keeping remote directory up to date'), so when I have a new file in remote I have to press the 'Synchronization' again.
Is there any way I can keep 'Synchronization' alive with 'both' mode?
Re: How to keep Sync both alive even after synced
Remote to local synchronization cannot work, as there's no way the server can notify WinSCP about a new file.
All you can do is to script a frequent synchronization in a loop.
There's actually an official WinSCP extension for "Remote to local synchronization" that does exactly that:
https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date
You can easily modify it to do "both" synchronization.
