Error Code 2 in the Winscp 5.13 at PutFiles.
kuzyaka
In the Winscp 5.13, in the execution:
transferResult = session.PutFiles("D:\*.pdf", "D:/", False, transferOptions)
I get an error:
cannot get real path for 'D:/'
no such file or directory
though
transferResult = session.GetFiles("D:/*.pdf", "D:\", False, transferOptions)
runs without errors.
In Winscp 5.11.3 and earlier, everything worked without errors.
Tell me, what's the problem?
Re: Error Code 2 in the Winscp 15.13 at PutFiles.
Please attach a full session log files both from 5.13 and 5.11.3.
kuzyaka
Re: Error Code 2 in the Winscp 5.13 at PutFiles.
Anonymous wrote:
Sending session log files both from 5.13 and 5.11.3.
martin, this is not "Anonymous," it's me, "kuzyaka", attached the session log files.
Sorry, I have error number winscp, correct 5.13 and 5.11.3, not 15.13 and 15.11.3.
If you login to the server in WinSCP GUI and navigate to your target directory, what path to you see on the top of the file list?
In the WinSCP GUI in my target directory at the top of the file list, I see: "/cygdrive/d/Apache24/htdocs/ShiShi/". This I see in all editions of WinSCP. And if I specify this path in session.PutFiles, the file is passed without error. But when specifying the target directory as "D:/Apache24/htdocs/shishi/" the error appears only in WinSCP 5.13 and only when the file is transferred (session.PutFiles). Functions (session.GetFiles and session.ListDirectory) in WinSCP 5.13 are executed without errors when specifying the target directory as "D:/Apache24/htdocs/shishi/".
Why is the session.PutFiles and session.GetFiles functions in WinSCP 5.13 behaving differently?
kuzyaka wrote:
martin, I believe that this is just a bug in WinSCP 5.13 and it just needs to be fixed.
No, it's not a bug in WinSCP. It's a bug (or misconfiguration) of your SFTP server.
The server does not support D:/Apache24/htdocs/new_year/ syntax in SSH_FXP_REALPATH call.
kuzyaka
You claim that my SFTP server does not support D:/Apache24/htdocs/new_year/ syntax in the SSH_FXP_REALPATH call.
When I worked with WinSCP 5.11.3, he supported it, and when working with WinSCP 5.13 it stopped supporting it?
Do not you find this strange?
5.11.3 didn't use SSH_FXP_REALPATH call in this case. 5.13 does. SFTP client is not only allowed to use SSH_FXP_REALPATH for any valid path, it's actually required to do so (while most SFTP clients actually fail to do that).
kuzyaka
martin, you never answered the main question:
Why in WinSCP 5.11.3 and earlier versions of the command
was executed without errors, and in WinSCP 5.13 there was an error?
Please answer directly to the question posed.
I've answered this directly in my previous post:
In other words, 5.13 follows SFTP specification more correctly than 5.11.3 did. And your buggy or misconfigured SFTP server cannot cope with that.
kuzyaka
martin, I understood you.
Only it turns out that 5.13 follows the SFTP specification more correctly only when executing the command session.PutFiles, and when executing the session.ListDirectory or session.GetFiles commands, does it not correctly follow the SFTP specification?
After all, teams
session.ListDirectory ("D:/")
session.GetFiles ("D:/*.pdf","D:\",False,transferOptions)
in WinSCP 5.13 are executed without errors.
And this is how to understand?
kuzyaka
Yes, that's correct.
Sorry, I did not understand.
What exactly is correct?
Your understanding of the problem.
kuzyaka
Do you expect that in the next updates WinSCP will also correctly support the SFTP specification in the session.ListDirectory and session.GetFiles commands?
I do not plan to change their implementation, unless it brings some benefit. It would not help you either, right? So why are you asking?
kuzyaka
OK!
I'm using the Cygwin SSH server.
Tell me, what do I need to configure on my server to support D:/Apache24/htdocs/new_year/ syntax in the SSH_FXP_REALPATH call?
I do not know. Maybe it's not even possible.
kuzyaka
OK!
I hope, that on my Cygwin SSH server the syntax /cygdrive/d/Apache24/htdocs/new_year/ in the SSH_FXP_REALPATH call, will WinSCP always support?
kuzyaka wrote:
OK!
There's no restriction on WinSCP side. It's all about the server.
