Is this possible to do from a script with WinSCP
solutionsville
Ft Worth
Martin,
I am trying to figure out if I can do this from a script via WinSCP.
Basically, it is launch a script, Telnet to another Internal IP, Login and then run two commands and exit from telnet, and end the connection.
Here is how I would do it form SSH or telnet;
Using SSH, it would look like this:
ssh <LAN2 IP address>
<login with linux user/pass, default = root/****>
<from linux prompt>
telnet 192.168.77.101 <this internally connects from the linux processor to the main processor’s command line>
<login with CCI password, default = *******>
debug val 0x00 <to turn off>
debug val 0xDF <to turn on>
Using telnet it would look like this:
telnet <LAN2 IP address> 2323
<login with CCI password, default = ********>
Re: Is this possible to do from a script with WinSCP
It's difficult to tell if it would even work with WinSCP.
But in any case, WinSCP is a file transfer client. So unless you need to combine a command execution with a file tramsfer, WinSCP's not the right tool for such a task.
Consider using Plink from PuTTY package.
https://the.earth.li/~sgtatham/putty/latest/htmldoc/Chapter7.html
https://stackoverflow.com/q/39361444/850848
