URGENT:. FileMask script error "Missing parameter for command 'put'
jatin1230
United States
Hi
I am new to WINSCP. I am trying to auto sync my local folder using timestamp only for hailstorm 2018 files which is "hail-2018*.csv.gz" from NOAA website.
I wrote this script below:
/command ^
"open ftp://username:password@ftp.ncdc.noaa.gov/" ^
"cd pub/data/swdi/database-csv/v2/" ^
"lcd ""D:\Data NOAA\HailZips""" ^
"put -filemask=*>=%%TIMESTAMP#mm-dd-yyyy%%" ^
"get hail-2018*.csv.gz" ^
"exit"
exit /b %WINSCP_RESULT%
ERROR: Missing parameter for command 'put'
Basically I want this script to run daily and sync my local folder with NEW and UPDATED hail 2018 files. Its a bit urgent, I would really appreciate somebody's help. Thanks a lot.
jatin1230
United States
Some progress but still stuck
Looks like some progress but I am still stuck
Updated the code to this (changes are only in timestamp row):
/command ^
"get -filemask=*>=%%TIMESTAMP#mm-dd-yyyy_%% hail-2018*.csv.gz " ^
"exit"
ERROR: Mask is invalid near '=03-15-2018'
This is how timestamp looks on the server: 3/14/18, 9:07:00 PM
Please help. Thanks.
jatin1230
United States
Finally it works!!
/command ^
"get pub/data/swdi/database-csv/v2/hail-2018*.csv.gz>=%%TIMESTAMP#yyyy-mm-dd%% D:\DataNOAALatest\" ^
"exit"
This downloads the latest hail-2018 file by timestamp
jatin1230 wrote:
A quick question whats the difference if i use get -latest or timestamp.
With -latest switch, you download the latest file. With timestamp, you download all files created/modified after the timestamp.
