bookmarks disappear after restarting WinSCP 5.13 (registry permissions issue)
Mithaldu
Mithaldu avatar
Germany
I'm using WinSCP 5.13 under Win10Pro.
I fixed the issue for myself, but figure it's worth it for you to know that there's a lacking error check here.
I could create bookmarks fine, and they worked, and they survived disconnecting/reconnecting. However if i closed WinSCP and reopened/reconnected, they were completely gone.
Using Process Monitor i found that WinSCP was being denied access on keys like:
HKCU\Software\Martin Prikryl\WinSCP 2\Configuration\Bookmarks\Local\root@109.74.203.4
HKCU\Software\Martin Prikryl\WinSCP 2\Configuration\Bookmarks\Remote\root@109.74.203.4
While still having full access to these paths:
Forcing the permissions to inherit allowed WinSCP to work fine again, however:
It would be good if WinSCP actually did access checks and informed the user, instead of trying to read those and silently failing.
Re: bookmarks disappear after restarting WinSCP 5.13 (registry permissions issue)
I will take a look at this issue.
