After hours backup ending in morning
AgedFast
Australia
Good weekend everyone,
I'm trying to automate large backups during my off-peak bandwidth.
What I've managed so far is from reading the WinSCP documents.
Currently I'm using the following batch with windows scheduler.
set TMPPATH=@@@@@@
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul ^
  /command ^
       "open sftp://$$$$$$:######@%%%%%%/ -hostkey=""******=""" ^
       "put ""d:/dump/*"" ""%TMPPATH%""" ^
for /r "%TMPPATH%" %%f in ("*.*") do move "%%f" "@@@@@@"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Then later I run
taskkill /f /im "WinSCP.exe"
However this batch isn't using parallel connections and following a search on WinSCP it appears as though its too complicated of a task to achieve through batch, this is when I found the following.
https://winscp.net/eng/docs/library_example_parallel_transfers#upload_csharp
My question is being that C# is a more in depth language would there be a way to add some line that if possible start and end at set time and leave running in background or at minimum end at set time so I can still see the following.
$ "Uploaded {0} files, totaling {1:N0} bytes"
Thanks for all support my only coding experience is HTML, thankfully C# looks like a clean enough language that I know at least the lines I need to change in the example.
Re: After hours backup ending in morning
At the beginning of the while (true) block, add:
        while (true)
            if (DateTime.Now.Hour >= 6)
                Console.WriteLine("It's 6 o'clock, aborting");
                break;
AgedFast
Australia
Thank you sir, you are an absolute legend.
Am I correct in assuming if I wanted it to run 6pm to 6am, all I would have to do is have >=12?
Edit - Never mind I've messed around and seem to have it working, thanks for everything.
The number is not a duration, but real clock (note DateTime.Now). So if you want to stop at 6:00 (am), keep my code as it is.
