Lftp for Windows - lftp on windows using WinSCP and Cygwin binaries.
user564758
I made this project using the wonderful WinSCP and other tools and wanted to share it with the WinSCP community, since without the flexibility of WinSCP this would not have been possible.
Lftp for Windows on Github
Reading the readme on GitHub is the best way to understand how this works but it is very simple to use and set up.
Summary:
This project makes using lftp on windows a very simple experience. It simply requires a template session is configured and you can use lftp via WinSCP custom commands. There is task scheduler support as well using special scripts.
Lftp is always the current cygwin version.
This project is 100% portable and works very well to take advantage of lftp.
Please take a look and see how i used WinSCP to bring a command line linux application to the average Windows user with WinSCP and ConEMU.
Re: Lftp for Windows - lftp on windows using WinSCP and Cygwin binaries.
Thanks for sharing this!
