Terminal Commands Fail with "cd no such file or directory"
i receive the cd "no such file" error in various scenarios, even tho i didn't enter cd.
error occurs when i launch WinSCP, when i do right-click > Duplicate on a file, and when i attempt to execute terminal commands.
commands work without error in Putty.
An unknown bash is being executed.
it seems winscp, or the remote host, is executing cd.
it appears the cd is trying to change from root to active directory, which is why the cd fails. The target dir is already the active dir.
version: 5.13 build 8172
windows 8.1
SFTP
host: 1and1 shared
log attached
windows 8.1
SFTP
host: 1and1 shared
Error changing directory to '/clickandbuilds/MediaWiki/MyWikis/extensions'
Command 'cd "/clickandbuilds/MediaWiki/MyWikis/extensions"'
failed with return code 1 and error message
-bash: line 17: cd: /clickandbuilds/MediaWiki/MyWikis/extensions: No such file or directory.
log attached
