Error when trying to delete file from remote site
eggi214
Manchester, UK
Hi there,
I've created a powershell script to upload and download a file from a remote FTPS servier.
The script does the following:
1. Uploads a file from my local dir
2. Moves the uploaded file into a local backup dir
3. Download files from the remote FTPS server to local dir
4. Remove downloaded file from the remote site.
I'm having issues with point 4. I can manually delete/upload files to that folder I'm trying to download from, but I get the following error when running the script.
Download of /outbound/tes.tst /outbound/* succeeded, deleting from remote
Error: Exception calling "Check" with "0" argument(s): "Can't get attributes of file '/outbound/tes.tst'.
File or folder '/outbound/tes.tst' does not exist."
My Script is
# Load WinSCP .NET assembly
Add-Type -Path "c:\Program Files (x86)\WinSCP\WinSCPnet.dll"
$localAckPath = "C:\Users\user\Documents\test files\ACK\"
$remoteAckPath = "/outbound/test/*"
$backupOrdPath = "C:\Users\user\Documents\test files\localbackup\"
$remoteOrdPath = "/inbound/test/"
$localOrdFilePath = "C:\Users\user\Documents\test files\file to upload\*"
# Set up session options
    Timeout = new-timespan -minutes 1
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "123.122.250.123"
    PortNumber = port
    UserName = "user"
    Password = "pass"
    FtpSecure = [WinSCP.FtpSecure]::Implicit
    TlsHostCertificateFingerprint = "fingerprint"
while($true)
try
    Write-Host "Checking..."
    # Connect
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
   $transferOptions.PreserveTimestamp = $False
   $transferResult =
            $session.PutFiles( $localOrdFilePath, "/inbound/", $False, $transferOptions)
            foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup"
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupOrdPath
            else
                Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
        $transferResult =
            $session.GetFiles($remoteAckPath, $localAckPath, $False, $transferOptions)
            # Success or error?
                Write-Host "Download of $($transfer.FileName) $($remoteAckPath) succeeded, deleting from remote"
            $filename = [WinSCP.RemotePath]::EscapeFileMask($transfer.FileName)
                $remoteAckPath = $session.RemoveFiles($filename)
            $remoteAckPath.Check()
            if ($remoteAckPath.IsSuccess)
                    Write-Host "Removing of file $($transfer.FileName) succeeded"
                else
                    Write-Host "Removing of file $($transfer.FileName) failed"
                #Move-Item $transfer.FileName $backupPath
            else
                Write-Host "Download of $($transfer.FileName) failed: $($transfer.Error.Message)"
    # Your code
        # Throw on any error
       # $transferResult.Check()
        # Print results
       # foreach ($transfer in $transferResult.Transfers)
         #   Write-Host "Upload of $($transfer.FileName) succeeded"
catch
    #exit 1
finally
    $session.Dispose()
#exit 0
   Write-Host "Sleeping..."
   Start-Sleep -Seconds 300
[/code]
Re: Error when trying to delete file from remote site
Btw, doesn't the FTP server automatically delete the files, once they are downloaded?
Did you test the same in WinSCP GUI (download and delete afterwards)? Can you post a log file for that?
