Sync INI file but ignore certain settings?
doomshark
Hi All,
I have synced my .ini file between by work and home PC via a VPN which works fine, but my home laptop runs windows from SSD and all my software is installed on a HDD i.e. install locations are different (Work = C:/Program Files/.. | Home = D:/Installed/...)
So can I get WinSCP to ignore this specific setting and configure it locally to each PC?
If not, what could be a work around/alternative solution?
Many thanks in advance :)
doomshark
settings the sync
Hi Martin,
I am trying to ignore the editor location in the synced .ini config file and store it locally to each installation, is that possible?
Re: settings the sync
What is "editor location"? Do you mean a path to editor executable? You can use an environment variable in WinSCP confirmation and set the variable differently on each host.
