Error listing directory '/'. Could not retrieve directory listing
dinesh.sargunam
Singapore
Hi All,
we are getting below error message when we tried to access FTPs through WINSCP.
The user name or password is incorrect.
in the logs we noticed that connection has been established. while starting session & reading remote directory it throws above error message. Have verified all the ports open at Firewall end. Below are WinScp logs. Please help.
. 2018-03-21 10:45:59.312 WinSCP Version 5.13 (Build 8172) (OS 10.0.14393 - Windows 10 Enterprise 2016 LTSB)
. 2018-03-21 10:45:59.312 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2018-03-21 10:45:59.312 Log level: Normal
. 2018-03-21 10:45:59.312 Local account: Domain\xxxxxx
. 2018-03-21 10:45:59.312 Working directory: C:\Program Files (x86)\WinSCP
. 2018-03-21 10:45:59.312 Process ID: 6180
. 2018-03-21 10:45:59.312 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2018-03-21 10:45:59.312 Time zone: Current: GMT+8 (Malay Peninsula Standard Time), No DST
. 2018-03-21 10:45:59.312 Login time: Wednesday, 21 March 2018 10:45:59 AM
. 2018-03-21 10:45:59.312 --------------------------------------------------------------------------
. 2018-03-21 10:45:59.312 Session name: servername.sg (Site)
. 2018-03-21 10:45:59.312 Host name: servername.sg (Port: 990)
. 2018-03-21 10:45:59.312 User name: (Password: No, Key file: No, Passphrase: No)
. 2018-03-21 10:45:59.312 Transfer Protocol: FTP
. 2018-03-21 10:45:59.312 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2018-03-21 10:45:59.312 Disable Nagle: No
. 2018-03-21 10:45:59.312 Proxy: None
. 2018-03-21 10:45:59.312 Send buffer: 262144
. 2018-03-21 10:45:59.312 UTF: Auto
. 2018-03-21 10:45:59.312 FTPS: Implicit TLS/SSL [Client certificate: No]
. 2018-03-21 10:45:59.312 FTP: Passive: No [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2018-03-21 10:45:59.312 Session reuse: Yes
. 2018-03-21 10:45:59.312 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2018-03-21 10:45:59.312 Local directory: C:\Users\dinesh_sargunam\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2018-03-21 10:45:59.312 Cache directory changes: Yes, Permanent: Yes
. 2018-03-21 10:45:59.312 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2018-03-21 10:45:59.312 Timezone offset: 0h 0m
. 2018-03-21 10:45:59.312 Username prompt (no username provided)
. 2018-03-21 10:46:04.651 Connecting to servername.sg:990 ...
. 2018-03-21 10:46:04.651 Connected with servername.sg:990, negotiating TLS connection...
. 2018-03-21 10:46:04.651 Verifying certificate for "" with fingerprint 3e:84:6b:16:e8:39:4a:35:fc:88:31:84:e9:f4:08:46:54:63:68:2e and 20 failures
. 2018-03-21 10:46:04.651 Certificate common name "rp-intsftp.rp.edu.sg" matches hostname
. 2018-03-21 10:46:04.682 Certificate verified against Windows certificate store
. 2018-03-21 10:46:04.698 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA384
. 2018-03-21 10:46:04.729 TLS connection established. Waiting for welcome message...
< 2018-03-21 10:46:04.729 220 Microsoft FTP Service
> 2018-03-21 10:46:04.729 USER domain\username
< 2018-03-21 10:46:04.729 331 Password required
> 2018-03-21 10:46:10.051 PASS *********
< 2018-03-21 10:46:10.067 230 User logged in.
> 2018-03-21 10:46:10.067 SYST
. 2018-03-21 10:46:10.067 The server is probably running Windows, assuming that directory listing timestamps are affected by DST.
< 2018-03-21 10:46:10.067 215 Windows_NT
> 2018-03-21 10:46:10.067 FEAT
< 2018-03-21 10:46:10.067 211-Extended features supported:
< 2018-03-21 10:46:10.067 LANG EN*
< 2018-03-21 10:46:10.067 UTF8
< 2018-03-21 10:46:10.067 AUTH TLS;TLS-C;SSL;TLS-P;
< 2018-03-21 10:46:10.067 PBSZ
< 2018-03-21 10:46:10.067 PROT C;P;
< 2018-03-21 10:46:10.067 CCC
< 2018-03-21 10:46:10.067 HOST
< 2018-03-21 10:46:10.067 SIZE
< 2018-03-21 10:46:10.067 MDTM
< 2018-03-21 10:46:10.067 REST STREAM
< 2018-03-21 10:46:10.067 211 END
> 2018-03-21 10:46:10.067 OPTS UTF8 ON
< 2018-03-21 10:46:10.067 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2018-03-21 10:46:10.067 PBSZ 0
< 2018-03-21 10:46:10.067 200 PBSZ command successful.
> 2018-03-21 10:46:10.067 PROT P
< 2018-03-21 10:46:10.067 200 PROT command successful.
. 2018-03-21 10:46:10.098 Connected
. 2018-03-21 10:46:10.098 --------------------------------------------------------------------------
. 2018-03-21 10:46:10.098 Using FTP protocol.
. 2018-03-21 10:46:10.098 Doing startup conversation with host.
> 2018-03-21 10:46:10.119 PWD
< 2018-03-21 10:46:10.120 257 "/" is current directory.
. 2018-03-21 10:46:10.120 Changing directory to "/".
> 2018-03-21 10:46:10.120 CWD /
< 2018-03-21 10:46:10.123 250 CWD command successful.
. 2018-03-21 10:46:10.123 Getting current directory name.
> 2018-03-21 10:46:10.123 PWD
< 2018-03-21 10:46:10.123 257 "/" is current directory.
. 2018-03-21 10:46:10.169 Retrieving directory listing...
> 2018-03-21 10:46:10.169 TYPE A
< 2018-03-21 10:46:10.169 200 Type set to A.
> 2018-03-21 10:46:10.169 PORT 10,60,112,151,240,215
< 2018-03-21 10:46:10.169 200 PORT command successful.
> 2018-03-21 10:46:10.169 LIST -a
. 2018-03-21 10:46:10.201 Data connection closed
. 2018-03-21 10:46:10.201 <Empty directory listing>
< 2018-03-21 10:46:10.201 550 The user name or password is incorrect.
. 2018-03-21 10:46:10.201 Could not retrieve directory listing
. 2018-03-21 10:46:10.201 LIST with -a failed, will try pure LIST
. 2018-03-21 10:46:10.201 Retrieving directory listing...
> 2018-03-21 10:46:10.201 TYPE A
< 2018-03-21 10:46:10.201 200 Type set to A.
> 2018-03-21 10:46:10.201 PORT 10,60,112,151,240,216
< 2018-03-21 10:46:10.201 200 PORT command successful.
. 2018-03-21 10:46:10.247 Data connection closed
. 2018-03-21 10:46:10.247 <Empty directory listing>
< 2018-03-21 10:46:10.247 550 The user name or password is incorrect.
. 2018-03-21 10:46:10.247 Could not retrieve directory listing
* 2018-03-21 10:46:10.310 (ECommand) Error listing directory '/'.
* 2018-03-21 10:46:10.310 Could not retrieve directory listing
* 2018-03-21 10:46:10.310 The user name or password is incorrect.
Re: Error listing directory '/'. Could not retrieve directory listing
Can you retrieve a directory listing using any other FTP client? (running on the same machine as WinSCP, using the same credentials)
