Can't make the program work from startup.
don williams
Is it necessary to make a donation to get this program to work so that I can try it out? When opened the small window is locked to the main window and menu items are not available. Both close and nothing can be done.
Re: Can't make the program work from startup.
No it's not necessary to donate.
But you have to login to a server to use WinSCP.
don williams
I have a website that I want to move. personal.inet.fi/cool/don.williams
If I enter the name and try to login, I get the message 405 method not permitted. How on earth do I get this thing started? I have to move my website because the provider is closing the service down.
Ask your provider for instructions to login to the webserver where you site is stored.
don williams
I went back to WS_FTP Pro and everything works as it should.
