WinSCP very slow to open connections (sessions) window
rchionna
Italy
Hello, I have about an hundred connections (sessions) configured, split in some directories and subdirectories.
When I run WinSCP, it take very long time (more than a minute) to show connections window; I'm aware that hundred (and above) connections are much items to load, but maybe it doesn't justify that slowness.
Thank you in advance and have a nice day to all,
Roberto
Re: WinSCP very slow to open connections (sessions) window
Are you using registry or INI file to save your configuration?
rchionna
Italy
Thank you for your reply, Martin.
I'm using latest version of WinSCP (5.13.1).
I tried both INI and Registry mode to save configuration, with the same results: about 30/40 secs. to show session window... quite frustrating because I need to connect many times in a day to several remote machines...
Have a nice day
Re: I do have the same problem with version 5.15.3
MarcC wrote:
Is there a patch for this ?
