Continuous Sych - Keeping Local Up to Date
blasword
There are some similar posts but I would like to confirm the full process that I have done.
I created a bat file like this:
@echo off
:loop
"C:\Program Files\WinSCP\WinSCP.com" ^
  /command ^
    "open sftp://ubuntu@xxxxxxxx.com/ -hostkey="xxxxxxxxxx" -privatekey="xxxxxxx" -timeout=180 -rawsettings PingType=1" ^
    "synchronize local c:/shares /var/www/shares" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
timeout /t 120
goto loop
Then, I run this bat once and it works indefinitely. Is this the correct way to do this?
Also, if a file is too large and doesn't finish in 120 seconds, will it be a problem in the next run?
Re: Continuous Sych - Keeping Local Up to Date
That's a question for you, not for us. We do not know, what you want to do.
No. It waits 120 seconds between the rounds. It does not limit a duration of a round.
