Synchronizing multiple unique folders in one ftps session possible?
jrp78
SoVA
Is this type of thing doable or is my code just bad. It stops after the first synchronize command and justs shows "winscp>"
@echo off
SET TIMESTAMP=log_%DATE:~-4%_%DATE:~4,2%_%DATE:~7,2%_%TIME:~0,2%%TIME:~3,2%%TIME:~6,2%.log
"D:\scripts\WinSCP-5.13-Portable\WinSCP.com" ^
   /log="D:\transfer_logs\%timestamp%" /loglevel=0 /ini=nul ^
  /command ^
    "open ftpes://user:pass@X.X.X.X:xx/ -certificate=""xx:xx:xx:xx:xx:xx:xx""" ^
   "option batch continue" ^
    "option transfer binary" ^
   "option synchdelete on" ^
   "synchronize local d:\inetpub\folder1\ /folder1/ -delete -criteria=either -filemask=""| thumbs.db; ~*.*""" ^
   "synchronize local d:\folder2\ /folder2/ -delete -criteria=either -filemask=""| thumbs.db; ~*.*""" EXIT
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
farnoise
Canada
I had the same issue, the problem with SYNC is, it only watches for one folder, in an infinite loop style. so in your case, it's just waiting for changes in FOLDER_1, it never gets to go to next line.
One way to fix that is use PUT instead. and iterate over your folders, the way you did now. now the issue with PUT is, it won't really "sync" it puts newer files there, but if you del something, it won't del from remote.
jrp78
It appears setting up symbolic links for all my folders into one folder then syncing that folder works but I was hoping to avoid having to do that :(
Re: Synchronizing multiple unique folders in one ftps session possible?
You have a space after the ^ at the end of the line with the first synchronize command. This effectively makes the ^ be ignored (it escapes the space, not the newline).
See https://winscp.net/eng/docs/faq_batch_file
