Syncronize not updating if the file size is the same
MConnolly
Dubuque, IA
I'm running an script that syncronizes content from a local directory to an FTP site.
We're using WinSCP version 5.13
The .bat file is calling the script correctly...
"C:\Program Files\WinSCP\WinSCP.exe" /ini=nul /script=C:\AutoJobs\ColorWeb\sync-pressrunplanner-pages.txt
The script itself works for new files and for files where the size has changed...
echo on
open ftp://[MyUserName]:[MyPassword]@[MyServer]
synchronize remote -delete -filemask="| */" Y:\ /
close
I tried adding the -critera=time flag, but that doesn't seem to be working for me...
echo on
synchronize remote -delete -criteria=time -filemask="| */" Y:\ /
close
Is my syntax wrong for the -criteria flag? I saw in the documentation I need to use SFTP instead of FTP if I want to use the "preserve timestamps" option, but I don't think that applies to me here.
Re: Syncronize not updating if the file size is the same
