Winscp Crashing - issues
imelendez
United States
I was first troubleshooting issues with command line run of winscp to a remote directory and noticed that it would get to completion and just drop out.
I looked up the server logs and saw that the connection was forcibly closed by the remote host.
2018/04/02 13:49:23 [542] Incoming connection request on SSH SFTP interface 13 at 10.10.0.241 accepted from 75.190.49.219
2018/04/02 13:49:23 [542] Client Identification: SSH-2.0-WinSCP_release_5.13.1
2018/04/02 13:49:23 [542] Algorithm negotiation complete: Proceeding with key exchange
2018/04/02 13:49:23 [542] Kex: 'ecdh-sha2-nistp256' Host Key: 'ssh-rsa' C2S : 'aes256-ctr, hmac-sha2-256, none' S2C : 'aes256-ctr, hmac-sha2-256, none'
2018/04/02 13:49:23 [542] Authenticating password for user 'cloud2'
2018/04/02 13:49:23 [542] Native user 'cloud2' authenticated
2018/04/02 13:49:23 [542] Channel Open: 'session', Sender Channel: 256, Init Window Size: 2147483647, Max Packet Size: 16384
2018/04/02 13:49:23 [542] Creating local channel: 1072
2018/04/02 13:49:23 [542] Channel Request: 'simple@putty.projects.tartarus.org', Recipient Channel: 1072, Subsystem Name: '', Reply: false
2018/04/02 13:49:23 [542] Channel Request: 'subsystem', Recipient Channel: 1072, Subsystem Name: 'sftp', Reply: true
2018/04/02 13:49:23 [542] [cloud2] Client SFTP version: 6
2018/04/02 13:49:23 [542] [cloud2] Real Path for '.'
2018/04/02 13:49:23 [542] [cloud2] Real Path for '/'
2018/04/02 13:49:24 [542] [cloud2] LStat: /
2018/04/02 13:49:24 [542] [cloud2] Real Path for '/'
2018/04/02 13:49:24 [542] [cloud2] LStat: /NC002.7z
2018/04/02 13:49:24 [542] [cloud2] Stat failed for /NC002.7z: The requested file does not exist
2018/04/02 13:49:24 [542] [cloud2] LStat: /NC002.7z.filepart
2018/04/02 13:49:24 [542] [cloud2] Stat failed for /NC002.7z.filepart: The requested file does not exist
2018/04/02 13:49:24 [542] [cloud2] File open command received for '/NC002.7z.filepart' requesting WRITE,CREATE TRUNC
2018/04/02 13:49:24 [542] File handle to '/NC002.7z.filepart' opened
2018/04/02 13:49:24 [542] [cloud2] Upload started for file 'C:\CBASYNC\NC002.7z.filepart'
2018/04/02 13:49:59 [542] Closing connection: An existing connection was forcibly closed by the remote host.
2018/04/02 13:49:59 [542] Connection terminated
When I run the commander GUI I am at login and after 5 to 10 seconds it crashes. Help?[/quote]
Re: Winscp Crashing - issues
Re: RE: Winscp Crashing - issues
