Can't get attributes of file No such file or directory
tzpow2
Hi
I am using C# code to download a file from FTP server and I am getting the "Can't get attributes of file No such file or directory" error. But there is the file. I can download it using GUI. It is very strange, if the test file is in "ROOT" directory, it works, but not in the sub folder. Also the folder looks strange. It is like "Jade:/PROD/Outbound". Anyone have this issue before?
Here is my code.
  string winscpPath = "C:\\Program Files (x86)\\WinSCP\\WinSCP.exe";
            string username = "username";
            string password = "abc123";
            string ftpSite = "SFTP.abc123.com";
            string localPath = @"\\191.26.25.22\JADE\DownloadFiles\";
           // string remoteFTPDirectory = "/"; //****Works if test file in root****
            string remoteFTPDirectory = "/PROD/Outbound";
            string sshKey = "ssh-dss 1024 2e:e0:68:f0:a0:40:12s3d1f2123s1dfsdf";
            Boolean winSCPLog = true;
            string winSCPLogPath = @"\\191.26.25.22\JADE\";
                //FtpSecure = FtpSecure.Implicit,
                //FtpMode = FtpMode.Active,
                //Timeout = new TimeSpan(0, 0, 120), //120 seconds
                Protocol = Protocol.Sftp,
                HostName = ftpSite,
                UserName = username,
                Password = password,
                PortNumber = 22,
                SshHostKeyFingerprint = sshKey
                // SshHostKeyFingerprint = sshKey for ssh
            try
                    // WinSCP .NET assembly must be in GAC to be used with SSIS,
                    // set path to WinSCP.exe explicitly, if using non-default path.
                    session.ExecutablePath = winscpPath;
                    session.DisableVersionCheck = true;
                    if (winSCPLog)
                        session.SessionLogPath = @winSCPLogPath + @"ftpLog.txt";
                        session.DebugLogPath = @winSCPLogPath + @"Ftpdebuglog.txt";
                    session.Open(sessionOptions);
                    RemoteDirectoryInfo rDirectory = session.ListDirectory(remoteFTPDirectory);
                    string filename = "";
                    for (int i = 0; i < rDirectory.Files.Count; i++)
                        string thisfile;
                        thisfile = rDirectory.Files[i].Name;
                        thisfile = thisfile.ToUpper();
                        if (thisfile.Contains("TEST") == true)
                            // session.MoveFile(remoteFTPDirectory + "/" + thisfile, remoteFTPDirectory + "/" + thisfile + ".txt");
                            session.GetFiles(thisfile, localPath, true);
                            filename = filename + thisfile + "\n";
                    session.Close();
            finally
Re: Can't get attributes of file No such file or directory
This might be the problem:
Use the file name as is, when calling session.GetFiles.
No, I tried removing that still getting the same error.
tzpow2
Hi the log is in the very first post. I am using version 5.7.6, and I can't upgrade it because the server that is running the Jobs is also the same version.
That's a log with ToUpper, hence useless.
You should not rely on an installed version of WinSCP. Your application should deploy it's own copy of WinSCP binaries.
See https://winscp.net/eng/docs/library_install#installing
