System Error 998 when uploading >2GB files to S3
Hi Martin,
Uploads of very large (video) files to S3, apparently >2GB, fail with a error box saying:
Observed on WinSCP 5.13 (Build 8172) on Windows 7 Enterprise SP1
Also observed on WinSCP 5.13.1 (Build 8265) on Windows 7 Professional SP1
Upgraded WinSCP to get S3 functionality, so cannot refer to earlier behaviour.
Protocol: S3
Interface mode: GUI, using Commander Mode
Steps to reproduce:
Thanks for looking at this.
Daniel
Uploads of less than 2GB or thereabouts on the same filesystem work fine (working examples were 1.6GB). Files can be opened locally in other tools.Error reading file D:\Users\filepath\file.mov
System Error. Code 998.
Invalid access to memory location
Protocol: S3
Steps to reproduce:
- Find or create a local file greater than 2GB.
- Navigate to local and remote (S3) directories.
- Drag local file onto S3 side of the commander interface
- Transfer popup window appears, then the Error popup window appears within a second.
Daniel
