Multiple GB worth of wscp*.tmp files in C:\Windows\Temp
unix-bomber
Virginia
Hey all,
I recently had a requirement to build a powershell script that performs SFTP/FTPS transfers that would survive reboot.
Operation and security constraints lead to me running the script as a service, to survive reboot.
After allowing the service to run for a day, I noticed my HDD was full. As it turns out, there were several Gb worth of files like 'wscp1048.017658A6.tmp' in C:\Windows\Temp
The code I've been running is here
https://github.com/unix-bomber/Powershell
(WinSCP code starts at line 1006)
I have several MB of transaction logs as well (There's a log for each time WinSCp downloads, or enumerates a foreign directory)
So far I've read that files that are edited via WinSCP, may be temporarily stored in C:\Windows\Temp but I don't know why they would persist between sessions/ runs
If anyone has had this issue, or can point me in the direction of a resource that can help I would be quite grateful.
Re: Multiple GB worth of wscp*.tmp files in C:\Windows\Temp
Does every WinSCP.Session instance leave a .tmp behind? Can you enable debug logging (Session.DebugLogPath) and attach the log here (for a session that left a .tmp behind).
unix-bomber
Virginia
It looks like there were 15 .tmp files left behind, from 20 Sessions. Some .tmp's were as small as 1KB and others as large as 300KB
I zipped the debug from one of the runs that had orphaned a .tmp
I was having issues uploading a zip, so I stored it here
https://drive.google.com/drive/folders/13onwOv6mhORt4TEj9DB4QGXtMm-BTRAp?usp=sharing
If that's not desirable I can continue to try to upload again later (perhaps it's the network I'm on)
(Potentially superfluous/ unnecessary info below)
The PFTS script installs as a Windows service, and executes a function (named 'run-pfts') every 30 seconds. The function in turn starts .ps1 files as jobs.
That said, there was one script running as a 'job handler' another script attempting to download files, and a third script attempting to upload files.
I noticed, that with debug mode on none of the files actually transferred
The log is not finished. It looks like the process was aborted. The process was running for 2 minutes (almost exactly). Isn't there some check that aborts the process, if it does not finish within 2 minutes?
unix-bomber
Virginia
I'm a fool.
The issue was with part of my code. By using Receive-Job instead of Get-Job, I wasn't getting the state of the child jobs.
.tmp files are no longer being orphaned
Thank you for the help Martin!
