Upgrade to 5.13 unusable Win10 Pro 64bit
dmcd
United Kingdom
Hello, Thanks in advance, I am relatively new to using WinSCP. For 6 months it has been fine until I upgrade to 5.13 on Win10 Pro 64bit 2TB storage (my archive) 16GB RAM, Intel Xeon CPU E5-1620 v2 3.70Ghz
It times out and has fatal errors even if restarted, running nothing else and left overnight to transfer files - it is basically unusable and I am really miss it. Also the checksums don't match when I check the remote server with ssh even if the size is exactly the same as the archived file on the PC.
Also tried SCP and SFTP
I have an older Mac with the same remote Unix remote drive on the network mounted on it which does work and the checksums match. It eliminates a problem with the remote drive. However isn't ideal for the job because it only has 500GB drive and I am working with PC files that I archive on the Win10 machine.
Re: Upgrade to 5.13 unusable Win10 Pro 64bit
Thanks for your report. What version are you using on the other machine? Do you remember what version did you have before the upgrade?
