Why Zero byte files are not transfer in WinSCP
Prabhas
India
Hi All ,
I am Transferring empty files to the server through WinSCP , however in log it is saying 0% transfer and nothing transfer to Server. Please let me know the reason and solution please.
Prabhas
Re: Why Zero byte files are not transfer in WinSCP
