.NET assembly - Cannot transfer some *.pgp files
Marius
Hi Together,
I have create an script for transfering some pgp files to an sftp. The strange thing is, that it is working if I have an txt file, if I will transfer the pgp - no file will be uploaded.
This is the basic code I'm using
# *** Daten kopieren ***
$transferOptions.TransferMode = [WinSCP.TransferMode]::Ascii
$localfile = $file.Name
$transferResult = $session.PutFiles("C:\export\$localfile", "/in/", $False, $transferOptions)
I have tried it with transfermode: binary, ascii and automatic - no differences
I also make a:
Write-Error $tranferResult.check() -> Result:
"C:\NEWExport.ps1 : Exception of type 'Microsoft.PowerShell.Commands.WriteErrorException' was thrown.
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,NEWExport.ps1"
Can someone please help me
Marius
Re: .NET assembly - Cannot transfer some *.pgp files
Please attach a full session log file for both .txt and .pgp transfer (using the latest version of WinSCP).
The log file seems to show a successful transfer. So what exactly is the problem? Do you mean that despite the transfer seemingly succeeded, you cannot see the uploaded file in the remote folder? If that's so, how exactly do you check that? If you upload the .pgp file in WinSCP GUI or using another SFTP client, can you see the uploaded file?
