Moves files instead of copying
justanumber
Earth
Running latest WinSCP (this also started happening in 5.13 build 8172) on Win 10 Pro.
When running a local AMPPS server and drag files from WinSCP (while connected to a live site) to folder within AMPPS, the files are "moved", not copied.
Also just noticed this behavior even without AMPPS running and dragging files to folder directly on C: drive (like C:Temp
I assume this is a bug since never happened in the past?
Real pain:)
Re: Moves files instead of copying
Did you check this FAQ?
Since 5.14, it is always possible to use drag&drop to move remote files to external applications, while copy is always the default operation.
