Slow with large folders
raddy
Firstly, many thanks for this great software, and as importantly your continued support.
I have a problem using WinSCP with folders that have a large number of files (~100k). When opening such a folder, there is a long wait as the file list is loaded, then any operation after that is very laggy.
I am on Windows 10, using WinSCP version 5.13 and SFTP connection. Hope you can help with this!
Raddy
Re: Slow with large folders
Local or remote folder?
