Authentication issues using .NET libraries
clayton.page
Canada
I apologize if this has been asked already but I couldn't find anything in the search. I have a webdav server that I can connect to without any issues using the winscp gui application but cannot connect to through the .NET libraries. The following is a code snippet that creates a session and attempts to connect. I get a "Authentication failed. Could not authenticate to server: rejected Digest challenge Connection failed." error. I have attached logs from both the gui app and .NET code. This seems pretty straight forward but I cannot get it to connect. Thanks.
    SessionOptions options = new SessionOptions
                                     Protocol = Protocol.Webdav,
                                     HostName = xxx.xxx.xxx.xxx,
                                     UserName = "xxxxxxxxx",
                                     WebdavRoot = "/files",
    session.Open(options);
    //unrelated code
Description: GUI log
Description: .NET log
Re: Authentication issues using .NET libraries
