Password always asked on SSH
josep
Hi
I have a raspberry pi3 with SSH server active, using keyfile, user and pass. Even I write the user:pass on the script, winscp always ask for the password after check the keyfile while connecting...Is there any way to add it to the script, or I must disable the passwrod cheking in SSh server?
Re: Password always asked on SSH
