panel columns not visible because of dragging columns too small
marcelloh
Holland
I'm using ther commander style view.
My kid moved my mouse and now a column is hidden (probably because it has a visible size of 0 width. And I looked everywhere how to solve this, but can't.
The columns are marked as visible, so that is not the point.
(It would be handy if there was a kind of reset option for this.)
How can I make the somehow hidden column really visible again (like: I was to see it with my bown eyes)
Re: panel columns not visible because of dragging columns too small
If there's a "hidden" column that is too narrow between two other columns (or next to first/last column), you will see your mouse cursor to change to two vertical lines with arrows pointing left and right (as opposite to single bold line) when you hover the cursor over columns separator. Just hold down a left mouse button to resize the column back.
Or just close WinSCP, delete below registry values, and restart it:
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\LocalPanel]
"DirViewParams"="..."
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel]
