PowerShell to copy multiple files to SFTP server
Userp
United States
I am using the sample script found here at WinSCP to upload files in a local directory to a directory on an SFTP server, then move the local file. The PowerShell script works, but only uploads one file to the SFTP directory at a time. I have to run the script multiple times to move all files. Not sure why that is. This is the script.
param (
    $localPath = "c:\ebanking\PosPay\*.*" ,
    $RemotePath = "/incoming/arp/" ,
    $backupPath = "C:\eBanking\Z_Arch\PosPay"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Set up session options
        HostName = "fdqn.computer.com"
        UserName = "xxxxxxx"
        Password = "xxxxxxxxxxx"
        SshHostKeyFingerprint = "ssh-rsa 1024 abcdefghijklmnopqrstuvwxyz"
    try
        # Connect
        # Upload files, collect results
        $transferResult = $session.PutFiles($localPath, $remotePath)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Output "Upload of $($transfer.FileName) succeeded, moving to backup" >> C:\eBanking\Z_Logs\BofAPP.log
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupPath
            else
                Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Any ideas why not all the files on local directory are not moved?
Re: Powershell to copy multiple files to SFTP server
disfunktedfish
I am having the same issue described by previous gentlemen with the PowerShell transfer and move script found here:
Moving local files to different location after successful upload
I don't deviate from the script above, I have my SFTP parameters in there and it will transfer one file and move it to the directory. It will only move one. Not sure what I need to do to make sure all of them get moved over.
Here is the log:
Description: Log file from moving one file.
disfunktedfish
Solution that worked for me
Hi All,
I found my issue and I'll post here for anyone to use this answer, hopefully at the very least it leads them in the right direction. My original issue is I was only moving one file at a time with this original configuration:
The ending solution here, at the end where @Stan.Gobien amends his transfer settings/upload settings is what ended up being the solution for me:
WinSCP .NET assembly (PowerShell) PutFiles from UNC path only uploads 1 file
#transferoptions
$transferOptions.FileMask = "*.*"
$transferOptions.FilePermissions = $Null # This is default
$transferOptions.PreserveTimestamp = $False
$transferResult = $session.PutFiles(($localPath + "*.*"), ($remotePath + "*.*"), $False, $transferOptions)
I added those options to my script and it worked like a charm. Hopefully everyone else gets help with this down the line if they should have the same issue.
Re: Solution that worked for me
Thanks for sharing your solution.
Note that only this makes any difference:
