PUT only sends a single file
sa6319
US CDT
PUT only sends a single file. Need to send all files.
Have tried variations ... *.img *.tad *.*
script runs ok, gives no error code.
code is:
lcd C:\abcde\tmp
cd /Test
put *.*
Re: PUT only sends a single file
