Error on opening Putty
Re: Error on opening Putty
How did you get putty.exe into WinSCP installation folder?
If you use the same path in Windows "Run" box (Win+R), does it start PuTTY?
So it's not a WinSCP installation folder? Are you using portable package of WinSCP?
Your obfuscation of screenshot makes it rather difficult for us, to understand what you are doing.
You also did not answer my other question (about running WinSCP from "Run" box).
