hostkey parameter includes double quotes
Ignas
I'm writing a script to connect server. Problem is that if I using double quotes, they are being included into the key. You can see it from the log:
"(Exception) **Host key does not match configured key "ssh-ed25519 256 xx:xx:xx..."!**".
If I put single quotes script simply doesn't run (just blinks cmd, but log being empty after this).
This is my script:
open sftp://root@XX.XXX.XXX.XX -privatekey=id_rsa.ppk -hostkey="ssh-ed25519 256 xx:xx:xx..."
put "license.txt" /root/license.txt
And I'm calling script like this:
.\WinSCP.exe /console /script="prod_to_server.txt" /ini=nul /log="scriptLog.log"
How to omit quotes in the hostkey?
Thank you in advance!
Re: hostkey parameter includes double quotes
Ignas
Providing log
. 2018-05-10 16:09:56.464 --------------------------------------------------------------------------
. 2018-05-10 16:09:56.464 WinSCP Version 5.13.1 (Build 8265) (OS 10.0.16299 - Windows 10 Home)
. 2018-05-10 16:09:56.464 Configuration: nul
. 2018-05-10 16:09:56.464 Log level: Normal
. 2018-05-10 16:09:56.464 Local account: Ignas
. 2018-05-10 16:09:56.464 Working directory: C:\Program Files (x86)\WinSCP
. 2018-05-10 16:09:56.464 Process ID: 11640
. 2018-05-10 16:09:56.465 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" "/script=prod_to_server.txt" /ini=nul /log=scriptLog.log
. 2018-05-10 16:09:56.465 Time zone: Current: GMT+3, Standard: GMT+2 (FLE Standard Time), DST: GMT+3 (FLE Summer Time), DST Start: 2018-03-25, DST End: 2018-10-28
. 2018-05-10 16:09:56.465 Login time: Thursday, May 10, 2018 16:09:56
. 2018-05-10 16:09:56.465 --------------------------------------------------------------------------
. 2018-05-10 16:09:56.465 Script: Retrospectively logging previous script records:
> 2018-05-10 16:09:56.465 Script: open sftp://root@xx.xxx.xxx.xx -privatekey=id_rsa.ppk -hostkey="ssh-ed25519 256 xx:xx:xx..."
. 2018-05-10 16:09:56.465 Session name: root@xx.xxx.xxx.xx (Ad-Hoc site)
. 2018-05-10 16:09:56.465 Host name: xx.xxx.xxx.xx (Port: 22)
. 2018-05-10 16:09:56.465 User name: root (Password: No, Key file: Yes, Passphrase: No)
. 2018-05-10 16:09:56.465 Tunnel: No
. 2018-05-10 16:09:56.465 Transfer Protocol: SFTP
. 2018-05-10 16:09:56.465 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2018-05-10 16:09:56.465 Disable Nagle: No
. 2018-05-10 16:09:56.465 Proxy: None
. 2018-05-10 16:09:56.465 Send buffer: 262144
. 2018-05-10 16:09:56.465 SSH protocol version: 2; Compression: No
. 2018-05-10 16:09:56.465 Bypass authentication: No
. 2018-05-10 16:09:56.465 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2018-05-10 16:09:56.465 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2018-05-10 16:09:56.465 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2018-05-10 16:09:56.465 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2018-05-10 16:09:56.465 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2018-05-10 16:09:56.465 Simple channel: Yes
. 2018-05-10 16:09:56.465 Return code variable: Autodetect; Lookup user groups: Auto
. 2018-05-10 16:09:56.465 Shell: default
. 2018-05-10 16:09:56.465 EOL: LF, UTF: Auto
. 2018-05-10 16:09:56.465 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2018-05-10 16:09:56.466 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2018-05-10 16:09:56.466 SFTP Bugs: Auto,Auto
. 2018-05-10 16:09:56.466 SFTP Server: default
. 2018-05-10 16:09:56.466 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2018-05-10 16:09:56.466 Cache directory changes: Yes, Permanent: Yes
. 2018-05-10 16:09:56.466 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2018-05-10 16:09:56.466 DST mode: Unix
. 2018-05-10 16:09:56.466 --------------------------------------------------------------------------
. 2018-05-10 16:09:56.466 Looking up host "xx.xxx.xxx.xx" for SSH connection
. 2018-05-10 16:09:56.466 Connecting to xx.xxx.xxx.xx port 22
. 2018-05-10 16:09:56.501 We claim version: SSH-2.0-WinSCP_release_5.13.1
. 2018-05-10 16:09:56.543 Server version: SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.4
. 2018-05-10 16:09:56.543 Using SSH protocol version 2
. 2018-05-10 16:09:56.543 Have a known host key of type ssh-ed25519
. 2018-05-10 16:09:56.581 Doing ECDH key exchange with curve Curve25519 and hash SHA-256
. 2018-05-10 16:09:57.220 Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them
. 2018-05-10 16:09:57.220 Host key fingerprint is:
. 2018-05-10 16:09:57.236 ssh-ed25519 256 xx:xx:xx...
. 2018-05-10 16:09:57.236 Host key does not match configured key ssh-ed25519 256 xx:xx:xx...
. 2018-05-10 16:09:57.236 Attempt to close connection due to fatal exception:
* 2018-05-10 16:09:57.236 Host key fingerprint is ssh-ed25519 256 xx:xx:xx....
* 2018-05-10 16:09:57.236 (Exception) **Host key does not match configured key "ssh-ed25519 256 xx:xx:xx..."!**
. 2018-05-10 16:09:57.236 Closing connection.
. 2018-05-10 16:09:57.236 Sending special code: 12
Please note, that I hidden some sensitive information in the script.
Re: Providing log
Sorry, but that log is useless. Your have removed the all hostkey fingerprints. Those are fingerprints of a public key. It's not sensitive/secret at all.
