Disable filename modification
Is there a way to disable the "Replace" filename modification feature using the .Net assembly?
This feature is available with the user interface https://winscp.net/eng/docs/ui_transfer_custom#other
but I'm not able to find how to disable the replace behaviour with the .Net assembly API.
