Issue with PuTTy client within WinSCP
Emericasktr1
United States
Hello I'm running into a huge issue. After entering in the host name, user and password, I the click on the 'Open session in PuTTy' key. After clicking on this, the terminal opens up and I am completely unable to type or paste anything into it. Yet when I open up PuTTy outside of WinSCP, it works completely fine, but my project needs to be done through WinSCP. Anyone have any ideas on how to fix this? Thanks
Re: Issue with PuTTy client within WinSCP
Please post PuTTY event log (right click PuTTY window title) for both working and non-working session. Also, please post a screenshot of a working session. What version of PuTTY are you using?
Emericasktr1
United States
Hello, thanks for the reply. I actually figured it out since you said to right click the PuTTy window title. Didn't know you could do that. Turning Local echo to Force On fixed it immediately! Thanks!
